RisingEdge
Output y is true, if the input u has a rising edge, otherwise it is false (y = edge(u))
    RisingEdge
Modelica/Blocks/MathBoolean
A rising edge of the Boolean input u results in y = true at thistime instant. At all other time instants, y = false.
The usage is demonstrated, e.g., in exampleModelica.Blocks.Examples.BooleanNetwork1.
RisingEdge_0
mo_pre_u_start
pre_u_start
Value of pre(u) at initial time
Scalar
true
false
RisingEdge_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
u
implicit
Boolean input signal
input
1
y
implicit
Boolean output signal
output
1
See Also
