Power
Output the power to a base of the input
    Power
Modelica/Blocks/Math
This blocks computes the output y as thepower to the parameter base of the input u.If the boolean parameter useExp is true, the output is determined by:
y = exp ( u * log (base) )
otherwise:
y = base ^ u;
Power_0
mo_base
base
Base of power
Scalar
mo_useExp
useExp
Use exp function in implementation
Scalar
true
false
Power_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
u
implicit
Connector of Real input signal
input
1
y
implicit
Connector of Real output signal
output
1
See Also
