BooleanToInteger
Convert Boolean to Integer signal
Modelica/Blocks/Math
This block computes the output yas Integer equivalent of the Boolean input u:
y = if u then integerTrue else integerFalse;
where u is of Boolean and y of Integer type,and integerTrue and integerFalse are parameters.
mo_integerTrue | integerTrue | Output signal for true Boolean input | Scalar | |
mo_integerFalse | integerFalse | Output signal for false Boolean input | Scalar |
mo__modifiers/value | Value |
u | implicit | Connector of Boolean input signal | input | 1 |
y | implicit | Connector of Integer output signal | output | 1 |
