Define Hyper Planes
Note: The Hyper Planes section is only available if
Method has been set to Deep learning as the
training method in the Builder tab.
Select the Hyper Planes radio button.
romAI draws two types of 3D plots:
- Hyper planes: The application evaluates the trained romAI model over a range of user-defined input values and displays the output as a hyper plane. One output at a time can be displayed.
- Scatter plots of Predictions vs Targets: The application evaluates the trained romAI model into a set of points contained in a dataset file and compares the output results with the target points contained in the same dataset file through a scatter plot. Only one output at a time can be requested.
