After the library has been installed, you can invoke the GUI from either the Tools
ribbon or the command window.
To invoke the GUI from the command window, type the command
romAIdirector. The GUI is shown as in the following image.
The GUI has the following sections:
File Menu contains generic file read/write options and generic utility actions.
Ribbon contains buttons to invoke actions that are applicable to the selected tabs.
Tabs provide a switching mechanism between Pre-Processor, Builder, and
Post-Processor functionalities.
Selection Tables provide options to select signals/models. In the case of
Pre-Processor, there are utilities present on the top of the table. These utilities
are applicable to table only.
Plot Canvas shows 2D/3D plots.
Info Panels show the information related to dataset/model.
Parameter Panel lets you edit the parameters related to dataset/model.
File name info shows the name of the files/folders in use.
Note the following commands and operations:
clear all: This command makes the romAI GUI unusable.
close all: This command closes the romAI GUI, in addition to other close commands, according
to Compose OML logic.
GUI instances: Use one GUI instance at a time. For example, you cannot open two
romAI GUIs at the same time in the same instance
of Twin Activate.
