Basic Use
Drag the romAI block into the modeling
window.
Double-click the block.
The romAI dialog opens.
Navigate to a directory containing a valid romAI
model.
The block automatically updates according to the selected romAI model.
In the mask, the inputs, state variables, and outputs of the model are reported together with their min and max values that occurred in the training phase.
If state variables exist, specify their initial values through the related edit
boxes.
After the block mask is defined, click OK.
The mask closes, and input and output ports of the block are shown.
You can now use the input and output ports to connect the romAI block to other blocks.
Click the Reload button in the block mask.
The romAI model reloads, and the initial values of the state variables, if they exist, are set back to the default values.
