Set Stationary Constraint Conditions
You set stationary constraint conditions so that the variation of the state variables within a defined range is not considered.
Select the state variable to be constrained.
In the State name column, click the ... button.
A list of available state variables is shown.
Double-click the desired state variable.
- Click OK.
- Enter a value to set the threshold, which defines the range.
Click OK.
The stationary conditions are defined. Stationary conditions can be helpful when dealing with stationary problems or slow-varying problems. In these cases, small numerical errors can lead to a divergence issue over time during a simulation.
