Set Output Constraint Conditions
Each output can be constrained if a certain condition is met on the inputs, state variables or the output itself.
Select the output to be constrained.
In the Output name column, click the ... button.
A list of available outputs is shown.
Double-click the desired state variable.
- Click OK.
Specify the constraint.
Click the Expression Builder
icon.
The Expression builder shows the variables and variable names for the expression.
Enter the condition in the Expression box and include the name of the listed
variable.
For example, the following condition forces the “SpringDamper_F” output to be greater than or equal to 0.
Note: Arithmetical operators can be included in the expression: (+ - * / ^), logical operators (| & ! ~), and relational operators ( > < >= <= == ~= <>). - After you have defined the output constraints, click OK.
