Architecture (SINDy)
When you use the SINDy method, the Architecture tab contains the approximate system equation.
Note: This section is only applicable if Method has been set to SINDy as the training method in the Builder tab.
When you have created a model using the SINDy method, you automatically get access to the approximate system equation. You can copy the formula and reuse it from the Architecture tab.
Depending on the precision set, the coefficient is updated with the corresponding digits.
This feature is useful for creating smarter and more robust control system algorithms.
