Navigating in Super Blocks
Navigate inside of a super block from the Project Browser or modeling window.
From the Project Browser, double-click a super
block.
The current model display clears, and the main diagram of the super block appears.Note: Navigation from the Project Browser is the same for masked and unmasked super blocks.
From the modeling window, select a super block and
double-click it, or press Ctrl + double-click the super
block.
The model display clears, and the main diagram of the super block appears.
To clear the display of the super-block, in the blank space around the super
block, double-click.
The super block closes and the model display returns.
