Understanding the Basics of SmartWorks using an Arduino Board
This tutorial will guide you through the process of learning the basics of the SmartWorks platform.
- Create a Thing and send data from an LDR sensor connected to an Arduino Nano 33 IOT to the platform.
- Create a Dashboard to visualize the data using MQTT.
- Add a button to control the MQTT architecture using HTTP.
Required Devices
- Arduino Nano 33 IOT
- Any analogic sensor (in our example is an LDR)
- A button
Get Started
To begin, download this file.
Click below to watch the tutorial.
Important Note
- Create an App type client_credentials as shown here and include the scopes
required. For example, for this tutorial:
- Scope category to perform actions related with categories (create, get information, delete).
- Enter the credentials for the app in the API Inspector as shown below and
click Get Token.
Figure 2. - Open the Auth tab and notice that it has been populated with the bearer
token. Use it to change the code and continue with the tutorial.
Figure 3.
