Create an Application in the Stream Processing Environment
The application aims to process the data received from a data source and a graphical programming environment is used to create the processing.
Open the Applications menu under Stream
Processing.
Select New Application.
Enter a name for the new Application and click
Create.
Create a diagram schema by adding the operations needed. An example is provided
below.
If following the example, click on input1. In
the Settings panel, select your input Data
source.
Click on the Calculation tile. In the Settings
panel, click on the Action drop-down menu and make a select. Enter
abs as the Field Name. This will usually
receive a positive value. Then click
to add an expression.
Click on aggregation1. In the Settings panel,
click the plus sign near the Group By field. Click the down arrow to
view the menu, and select abs.
Click on output2. In the Settings panel, click
the Data Consumer down arrow key and select your output Data
source.
source.
