EdgeOps Cloud Management Tools
The EdgeOps Cloud Management tools are designed to help you
better manage and control your deployed clusters, as well as the code that you
intend to deploy. These tools are broken into several pieces:
- Cluster Management - To help you provision edge hardware and manage edge deployments.
- Resource Catalog - To hold the encapsulations of the code you wish to deploy, in the form of YAML documents.
- Edge Applications - To group resource templates together into one, releasable set.
