LBC Mode
The LBC mode displays the entities assigned with boundary conditions in colors instead of showing markers.The UI is switched to this mode automatically when the boundary conditions of Acusolve,Molding and Eflo solutions are assigned or modified.The following options are listed in the UI | Right-click for the LBC display mode.
Display in Color | LBC
This option is used to enable the LBC color mode.
