Plot Convergence
Introduction
Plot Convergence is used to track the progress of the Solution and also to understand if the critical parameters are varying in the correct trend.
Features
- Solver convergence plotting is supported for solution, when background solve is in progress and also for completed solutions.
- List of Solvers for which plotting is supported,
- Radioss
- ElectroFlo
- OptiStruct - Non linear static solutions only
- AcuSolve - Solved solutions only
