Right-Click Options
Navigating to the new Post ribbon shows the following right-click options.
Hide: Use this option to hide the selected entities.
Isolate: Use this option to display only the selected entity.
Clear Selection: Supported to select the surfaces, this option clears the selected entities.
Shaded View: Use this option to switch from the wireframe display to the shaded display.
Wireframe View: Use this option to display only the face edges of the model.
Display Face Edges: Use this option to display the face edges of the model.
Hide Results: Use this option to switch back to Geometry visibility by hiding the flow post results display and its right-click options in the user interface.
