Logging and Monitoring
Viewing Logs
View the latest 300 rows of a Logging Level on the Logs tab:
  • FINEST (lowest level)
  • FINER
  • FINE
  • CONFIG
  • INFO (default level)
  • WARNING
  • SEVERE (highest level)
  1. Under the System tab, click Logs. Initially, the default level (INFO) logs are displayed.
  2. Select another Logging Level in the drop-down.
    For example: FINEST
    The latest 300 rows of the selected log level or higher are fetched.
  3. You can also click any of the following buttons:
    •  to pause the logging, it changes to
    •  to resume the logging
    •   to copy log to clipboard
    •  to clear the logs
(c) 2013-2024 Altair Engineering Inc. All Rights Reserved.
