Supported Calculation Functions
| Operator | Name | Description | Example | Nullability |
abs |
Absolute Value |
abs(number) Find the absolute value of a number. Parameter:
abs(-47.11) = 47.11 |
array |
Array |
array(size,value) Create an array of specified size and initialize with the given value. Parameters:
array(5, 1.1) |
a |
atan |
Arc Tangent |
atan(ordinate, abscissa) Get the inverse tangent of a number. Parameters:
atan(1.0) = 0.785398 |
ceil |
Ceiling |
ceil(number) Returns the smallest double value that is greater than or equal to the argument and Parameter:
ceil(4.7) = 5.0 |
clock |
Clock |
Returns the current system Date/Time value. |
clock() |
concat |
Concatenate |
concat(text1,text2) Joins two text values. Parameters:
concat(‘olle’,’pelle’) = ‘olle pelle’ |
cos |
Cosine |
cos(number) The natural logarithm (base e) of a real value. Parameter:
cos(0.0) = 1.0 |
cosh |
Hyperbolic Cosine |
cosh(number) Get the hyperbolic cosine of the number. Parameter:
cosh(0.0) = 1.0 |
cot |
Cotangent |
cot(number) Get the cotangent of the number. Parameter:
dateDiff |
Date Difference |
dateDiff(startDatetime,endDatetime,unit) Calculates the difference in whole units between two time values, the return value is positive if endDatetime comes after startDatetime, and is negative if endDatetime comes before startDatetime. Valid units are ‘DAYS’, ‘HOURS’, ‘MINUTES’, ‘SECONDS, ‘’MILLISECONDS’, ‘MICROSECONDS’, Parameters:
dateDiff(#2019-06-17#,#2019-06-14#,’DAYS’) = 3 |
dateDiff2 |
Date Difference |
Calculates the difference in fraction units between two time values, the return vallue is positive if endDatetime comes after startDatetime, and is negative if endDatetime comes before startDatetime. Valid units are ‘DAYS’, ‘HOURS’, ‘MINUTES’, ‘SECONDS, ‘’MILLISECONDS’, ‘MICROSECONDS’, Parameters:
dateDiff2(#2019-06-17T12:00:00#,#2019-06-14T00:00:00#,’DAYS’) = 3.5 |
datePart |
Date Part |
Returns a specified part of a time value, the result is an integer value. Valid units are ‘DAYS’, ‘HOURS’, ‘MINUTES’, ‘SECONDS, ‘’MILLISECONDS’, ‘MICROSECONDS’, Parameters:
datePart(#1973-07-23#,’YEARS’) = 1973 |
dateTrunc |
Date Truncate |
dateTrunc(datetime,datetimePart) Truncates the specified time value to the accuracy specified by the time_part. Valid units are ‘DAYS’, ‘HOURS’, ‘MINUTES’, ‘SECONDS, ‘’MILLISECONDS’, ‘MICROSECONDS’, Parameters:
dateTrunc(#1973-07-23T12:34:56#,’YEARS’) = #1973-01-01T00:00:00# |
exp |
Exponential |
exp(number) Find the value of e raised to the power of a number. Parameter:
exp(0.0) = 1.0 |
find |
Find |
find(findText,withinText,startPosition) Returns the starting position of one string within another string, given a starting position. Parameters:
find(‘ab’,’drabant’) = 3 |
floor |
Floor |
floor(number) Returns the largest real value that is less than or equal to the argument and is equal to a mathematical integer. Parameter:
floor(4.7) = 4.0 |
get |
Get |
get(array,position) Gets the nth element of the array. Parameters:
NOTE: Index of the array starts with 0. |
get(array(5,1.1),1) = 1.1 |
a |
if |
If |
if(condition,exprIfTrue,expIfFalse) The function provides branching capability. If condition is true, then it returns exprIfTrue, else it returns exprIfFalse. Parameters:
if(a < b, a,b) |
a |
ifNull |
ifNull |
ifNull(expression,altValue) The ifNull function returns the specified value if the expression is null, otherwise Parameters:
ifNull(null, ‘b’) = ‘b’ |
a |
index |
Index |
index(array,text) Sorts the input array and outputs a lookup index. Parameters:
index(array(3,#1973-07-23#),’asc’) |
intpow |
Integral Power |
intpow(number,power) Raise a number to a power. Parameters:
intpow(2.0, 3.9) = 8.0 |
invert |
Invert |
Inverts a lookup index. Since the index function returns an inverse permutation, you can apply the invert function which will turn it into a forward permutation (or rank). |
left |
Left |
left(text,numofChars) Returns the leftmost characters from a string producing a new string. Parameters:
left(‘olle’, 3) = ‘oll’ |
len |
Length |
len(value) Returns the number of characters in a string or the number of elements in an array. Parameter:
len(‘olle’) = 4 |
ln |
Logarithm |
ln(number) The natural logarithm (base e) of a real value. Parameter:
ln(1) = 0 |
log |
Logarithm |
log(number) Logarithm with base 10. Parameter:
log(1000.0) = 3.0 |
logn |
Logarithm |
logn(number,logBase) Returns the Log Based N of Input. Parameters:
logn(4711.0,4711.0) = 1.0 |
lower |
Lower |
lower(text) Convert text to lower case. Parameter:
lower(‘OLLE’) = ‘olle’ |
a |
max |
Maximum |
Maximum of the two numbers. |
max(11.0, 47.0) = 47.0 |
mid |
Mid |
mid(string,startPosition,numofChars) Returns the characters from the middle of a text string, given a starting position Parameters:
mid(‘olle’, 2,2) = ‘ll’ |
min |
Minimum |
Minimum of the two numbers. |
min(47.0, 11.0) = 11.0 |
pow |
Power |
pow(-2.0, 7.0) = -128.0 |
proper |
Proper |
proper(text) Converts a text to proper case; the first letter in each word in uppercase, and all parameter:
proper(‘olle asp’) = ‘Olle Asp’ |
a |
random |
Random |
random(minimumValue,maximumValue) Returns a random number with a positive sign. Parameters:
random(12.0) get a floating-point random number greater than or equal to 0.0 and |
replaceall |
Replace All |
replaceAll(string,oldText,newText) Replaces all occurences of the pattern with the replacement string. Parameters:
replaceAll(‘axa’, ‘a’, ‘b’) = ‘bxb’ |
a |
replaceFirst |
Replace First |
replaceFirst(string,oldText,newText) Replaces the first occurrence of the pattern with the replacement string. Parameters:
replaceFirst(‘axa’, ‘a’, ‘b’) = ‘bxa’ |
a |
right |
Right |
right(text,numofChars) Returns the rightmost characters from a string producing a new string. Parameters:
right(‘olle’, 3) = ‘lle’ |
rnd |
Rnd |
rnd(scaleValue) Returns a random number with a positive or negative sign depending on scale value. Parameter:
round |
Round |
round(number,digits) Round a number to a given number of digits. Parameters:
round(47.11) = 47.0 |
set |
Set |
set(array,position,newvalue) Sets the nth element of the array. Parameters:
NOTE: Index of first element starts with 0. |
set(array(5, 1.1), 1, 2.2) |
a |
sign |
Sign |
sign(number) Get the sign of a number, returns one if positive, negative one if negative, and Parameter:
sign(7) = 1 |
sin |
Sine |
sin(number) Get the sine of the number. Parameter:
sinh |
Sinus Hyperbolic |
sinh(number) Get the sinus hyperbolic of the number. Parameter:
sinh(0.0) = 0.0 |
sort |
Sort |
Applies a lookup index to an array. |
sqr |
Square |
sqr(number) Returns square of the number. Parameter:
sqr(3) = 9 |
sqrt |
Square Root |
sqrt(number) Returns square root of the number. Parameter:
sqrt(9.0) = 3.0 |
tan |
Tangent |
tan(number) Get the tangent of the number. Parameter:
tan(0.0) = 0.0 |
trim |
Trim |
trim(text) Get the input text stripped of leading or following spaces. Parameter:
trim(‘ olle ’) = ‘olle’ |
a |
trunc |
Truncate |
trunc(number,digits) Truncate a number to a given precision. Parameters:
trunc(47.11) = 47.0 |
upper |
Upper |
upper(text) Convert text to upper case. Parameter:
upper(‘olle’) = ‘OLLE’ |
