Properties: Streams
The majority of configuration options for the server are set in the Streams.properties file in the <AppData> directory (e.g., C:\streamsserverdata\). If this file does not exist when the server starts, it will create it with all default values. When the server starts after an upgrade, it may add new properties and remove deprecated ones.
You can optionally move sensitive properties like passwords and URLs from this file, where they are stored in clear text, into a file named Secret.properties in the same directory. The Secret.properties file stores values encrypted, and you can manage it with PCLI. A property can only be defined in one of these files at a time.
The following properties can be set in the property files:
Property
Access
Attribute
access.administrator.groups
The role that is mapped to the administrator group.
Default Value
admin
Property
Access
Attribute
access.administrator.users
Normally administrator access should be handled with the access.adminstrator.groups mapping, but for scenarios where the authentication cannot provide roles or you want to make exceptions for specific users, you can list individual usernames in this property.
Any user listed here will get administrator access, regardless of their roles. Separate multiple users with the access.list.delimiter.
Default Value
Property
Access
Attribute
access.default.roles
The default roles applied to all users of the server.
For example, if access.default.roles=DESIGNER,ADMINISTRATOR and a user with a VIEWER role logs on to the server, then the user will simultaneously have a VIEWER, DESIGNER, and ADMINISTRATOR roles.
However, if no default roles are wanted, then leave the property blank.
NOTE:The roles that can be assigned in this property can only be ADMINISTRATOR, VIEWER, ANONYMOUS, and/or DESIGNER. This property is case sensitive.
Default Value
VIEWER
Property
Access
Attribute
access.designer.groups
The role that is mapped to the designer group.
Default Value
designer
Property
Access
Attribute
access.designer.users
Normally designer access should be handled with the access.designer.groups mapping, but for scenarios where the authentication cannot provide roles or you want to make exceptions for specific users, you can list individual usernames in this property.
Any user listed here will get designer access, regardless of their roles.
Default Value
Property
Access
Attribute
access.viewer.groups
The role that is assigned to the viewer group.
NOTE: Currently not in use. Development ongoing.
Default Value
Property
Access
Attribute
access.viewer.users
Normally viewer access should be handled with the access.viewer.groups mapping, but for scenarios where the authentication cannot provide roles or you want to make exceptions for specific users, you can list individual usernames in this property.
Any user listed here will get viewer access, regardless of their roles.
Default Value
Property
Access
Attribute
The value delimiter to use when parsing access groups.
Examples:
access.list.delimiter=,
access.administrator.groups=group1,group2
The groups are mapped to {'group1', 'group2'}
access.administrator.groups=group1;group2,group3
The groups are mapped to {'group1;group2', 'group3'}
access.list.delimiter=;
The groups are mapped to {'group1', 'group2,group3'}
Default Value
',' (comma)
Property
Authentication: Header
Attribute
authentication.header.role.delimiter
The delimiter used to separate the roles. Example: role1, role2,role3
Default Value
',' (comma)
Property
Attribute
authentication.header.roles
The name of the header that contains all the roles.
Default Value
Property
Attribute
authentication.header.rolesdynamic
Supports the ability to create dynamic roles using free form patterns or string replacement.
To create dynamic roles, use '{header value to be used}'.
Example: authentication.header.rolesdynamic={HEADER_ROLES},financials,role_for_company_{HEADER_COMPANY}
Given this table:
KEY
VALUE
HEADER_ROLES
designer, watcher
HEADER_COMPANY
industrials, consumers
Then the roles to create the authentication token will be the following:
  • designer
  • watcher
  • financials
  • role_for_company_industrials
  • role_for_company_consumers
Default Value
Property
Attribute
authentication.header.username
The name of the header that contains the username
Default Value
Property
Attribute
authentication.header.validate.token
If set to true, the authentication will validate the token. If set to false, the authentication of every request will be based on headers.
Default Value
Property
Authentication: Logout
Attribute
authentication.logout.redirect.url
Takes a URL as a parameter. Clicking the logout button redirects the user to the
specified URL.
If this property is not set, user will be returned to the start page of Panopticon.
Default Value
Property
Authentication: OAuth 2.0
Attribute
authentication.oauth2.client.ID
The ID of the OAuth 2.0 client.
Default Value
Property
Attribute
authentication.oauth2.client.secret
The secret used by the OAuth 2.0 client.
Default Value
Property
Attribute
authentication.oauth2.identity.attribute.roles
The attribute that will be extracted from the identity response and used as the role. There can be multiple assigned roles for a user.
Default Value
Property
Attribute
authentication.oauth2.identity.attribute.roles.pattern
akes regex used to extract the roles from the OAuth 2.0 server identity response.
For example, the returned string:
cn=admin,ou=groups,dc=openam,dc=openidentityplatform,dc=org,cn=designer,ou=groups,dc=openam,dc=openidentityplatform,dc=org
contains two roles, admin and designer
The regex to extract the roles is cn=([^,]+).
Default Value
Property
Attribute
authentication.oauth2.identity.attribute.username
The attribute that will be extracted from the identity response and used as the username.
Default Value
Property
Attribute
authentication.oauth2.identity.method
The method on how the access token is passed along in the identity request. Supported values are QUERY, BODY, and HEADER.
Default Value
QUERY
Property
Attribute
authentication.oauth2.identity.url
The URL to the REST service that provides details about the authenticated user.
Default Value
Property
Attribute
authentication.oauth2.login.callback.url
The callback URL. The URL should be the same as one of the specified callback URLs used by the client. The URL should refer to Panopticon Streams.
Default Value
Property
Attribute
authentication.oauth2.login.redirect.url
Redirects the user to the specified URL after successfully logging in. This property can be left blank, in which case the user is redirected to the URL they requested to access.
Default Value
Property
Attribute
authentication.oauth2.login.response.type
The response type. The only response type that is currently supported is CODE. The value can also be left blank.
Default Value
Property
Attribute
authentication.oauth2.login.scope
The requested scope. The field can be left blank.
Default Value
Property
Attribute
authentication.oauth2.login.url
The URL to the OAuth 2.0 login resource.
Default Value
Property
Attribute
authentication.oauth2.logout.redirect.url
Logging out revokes the token from the authentication server if the property authentication.oauth2.logout.url is set to the revocation URL. If this property is not set, the server will only remove its own token.
If none of these properties are set, the server will attempt to redirect to the start page of Panopticon when logging out.
Default Value
Property
Attribute
The URL to the OAuth 2.0 logout resource. This field can be left blank.
Default Value
Property
Attribute
authentication.oauth2.token.method
The method on how the token should be retrieved. Supported values are QUERY, BODY, and HEADER.
Default Value
Property
Attribute
authentication.oauth2.token.url
The URL to the OAuth 2.0 token resource.
Default Value
Property
Service Authentication Level
Attribute
authentication.role
The authentication role.
Default Value
Property
Attribute
authentication.required
The property that will make the authentication required. It will force the user to login in order to use any of the services provided by the server.
Default Value
true
Property
Authentication: SAML
Attribute
authentication.saml.serviceprovider.id
The ID of the service provider configured in the IdP.
Default Value
Property
Attribute
authentication.saml.assertionconsumerservice.url
The URL to the Panopticon assertion consumer service. URL: [Protocol]://[Host]:[Port]/[Context]/server/rest/auth/login
Default Value
Property
Attribute
authentication.saml.identityprovider.url
The URL to the IdP login service.
Default Value
Property
Attribute
authentication.saml.assertion.username
User attribute for username configured in the IdP.
Default Value
Property
Attribute
authentication.saml.assertion.roles
User attribute for roles configured in the IdP.
Default Value
Property
Attribute
authentication.saml.certificate.name
The name of the certificate used to validate signature and/or sign outgoing SAML messages
Default Value
Property
Attribute
authentication.saml.certificate.password
The password of the certificate used to validate signature and/or sign outgoing SAML messages.
Default Value
Property
Attribute
authentication.saml.challenge.required
This property determines whether the IdP-first authentication with SAML is enabled or not. To enable, set this property to false.
Default Value
true
Property
Attribute
authentication.saml.identityprovider.logout.url
The URL to the IdP logout service.
Default Value
Property
Attribute
authentication.saml.keystore.file
The location of the Keystore file that contains the certificate.
Default Value
Property
Attribute
authentication.saml.keystore.password
The password to the Keystore file.
Default Value
Property
Attribute
authentication.saml.identityprovider.certificate.file
Takes a file path to a certificate file that contains the IdP’s public key.
Default Value
Property
Attribute
authentication.saml.identityprovider.signature.validation.required
Specifies whether to require a valid IdP signature to be present on the SAML response.
Default Value
false
Property
Attribute
authentication.saml.provider
The IdP provider. Possible values are OPENSAML, OPENAM
Default Value
OPENSAML
Property
Attribute
authentication.saml.keystore.type
The key store type. Possible values are JKS, JCEKS, PKCS12
Default Value
JKS
Property
Attribute
authentication.saml.login.redirect.url
Default Value
Property
Attribute
authentication.saml.logout.redirect.url
Redirects the user back to the specified URL after logging out. This is mainly used with a proxy. In which case, Panopticon Real Time does not know the endpoint which the user is going towards to, and therefore cannot redirect the user back to the Overview page. If you are using OpenAM this is required, otherwise this property can be left blank.
Default Value
Property
Attribute
authentication.saml.openam.meta.alias
The meta alias for the IdP if you are using OpenAM.
Default Value
Property
Attribute
authentication.saml.protocolbinding
Protocol binding for the use of SAML authentication. Possible values are HTTP-Redirect, HTTP-POST, HTTP-Artifact, HTTP-POST-SimpleSign, or SOAP.
Default Value
HTTP-Redirect
Property
Service authentication login request
Attribute
authentication.timeout.callback
The timeout (in milliseconds) for the user between initiated login and callback. The default value is five minutes.
Default Value
300000
Property
Authentication: Token
Attribute
authentication.token.cookie
Used when sticky load balancer is using cookies.
Default Value
stoken
Property
Attribute
authentication.token.domain
The domain in which the token cookie should be registered under.
Default Value
Property
Attribute
authentication.token.persistence
This property is used to determine if the token should persist if the browser is closed or if it should only last while the browser is open. There are two possible
values: PERSISTENT and SESSION. PERSISTENT will persist the token in the browser even if the browser has been closed and reopened. SESSION will remove the token from the browser if it is shutdown.
IMPORTANT:
After modifying the property value to SESSION, ensure to clear the AppData/Token folder before starting the server.
Default Value
PERSISTENT
Property
Attribute
authentication.token.refreshable
This property determines if the token can refresh itself. The web client can identify if the token is about to expire and then request a new token with the existing token. A token is refreshable if the property is set to true. The token will expire andinvalidate the user session if the property is set to false.
Default Value
true
Property
Attribute
authentication.token.secret
The secret is used to sign the token. The secret will be auto-generated when the server starts for the first time.
NOTE: This value should be kept a secret.
Default Value
Auto-generated
Property
Attribute
authentication.token.validity.seconds
The number of seconds that the token should be valid.
Default Value
604800
Property
Authentication
Attribute
authentication.type
The type of the authentication mechanism that will be used on Panopticon Streams.
Default Value
BASIC
Property
Cache
Attribute
cache.plugin.ID
The ID of the cache plugin that will be used. Possible value: BinaryTableFile-Cache
Default Value
Property
Cache
Attribute
cache.purge.condition
The condition for determining when the cache should be purged or cleared. Possible values: NONE, MEMORY.
Default Value
MEMORY
Property
Cache
Attribute
cache.purge.condition.memory.threshold
The memory threshold used to determine if the cache should be purged or not. The values are presented in percent, 0-100. 80 means that the cache will be purged if the memory consumption reaches 80 % or more.
Default Value
80
Property
Cache
Attribute
cache.purge.enabled
Enable or disable the purge functionality. Possible values: true, false
Default Value
true
Property
Cache
Attribute
cache.schedule.clear.enabled
Enable the cache clearing schedule. This is scheduling the clear cache operation which will remove all the expired cache entries.
Default Value
true
Property
CEP: Application
Attribute
cep.application.autostart
Determines whether all of the stored applications in the Streams server should auto start when Panopticon Streams starts.
Default Value
false
Property
CEP: Application
Attribute
cep.kafka.application.state.path
Where the tmp folder of Panopticon Streams data are created.
Default Value
C:/PanopticonStreams/Data/tmp/kafka-streams
Property
CEP: Kafka
Attribute
cep.kafka.connection.timeout
The connection timeout towards Kafka. The value is presented in milliseconds.
Default Value
10000
Property
CEP: Kafka
Attribute
cep.kafka.input.retention.ms
Specifies the retention period of input streams.
Default Value
60000
Property
CEP Kafka
Attribute
cep.kafka.monitoring.consumer.interceptor
Names of classes that will be used to monitor data consumed from topics in a Streams application. In addition, these are hooks that will allow an external application
to inspect this traffic.
NOTE: The default value enables the Confluent Control Center to show metrics for a Streams application.
Default Value
io.confluent.monitoring.clients.interceptor.MonitoringConsumerInterceptor
Property
CEP Kafka
Attribute
cep.kafka.monitoring.producer.interceptor
Names of classes that will be used to monitor data produced to topics in a Streams application. In addition, these are hooks that will allow an external application
Default Value
io.confluent.monitoring.clients.interceptor.MonitoringProducerInterceptor
Property
CEP: Kafka
Attribute
cep.kafka.output.retention.ms
Specifies the retention period of output streams.
Default Value
900000
Property
CEP: Kafka
Attribute
cep.kafka.properties
The user-defined file that contains the properties for controlling the Kafka configurations in Panopticon Streams.
Default Value
kafka.properties
Property
CEP: Kafka
Attribute
cep.kafka.schemaregistry.url
The URL to the Schema Registry.
Default Value
http://localhost:8081
Property
CEP: Kafka
Attribute
cep.kafka.servers
The URL to all the Kafka servers.
Default Value
localhost:9092
Property
CEP: Kafka
Attribute
cep.kafka.session.timeout
The timeout for the Kafka session. The value is presented in milliseconds.
Default Value
15000
Property
CEP: Kafka
Attribute
cep.kafka.table.retention.ms
Specifies the retention period for tables.
Default Value
86400000
Property
CEP: Kafka
Attribute
cep.kafka.topic.partitions
Propagates the server-wide default for topic partitions.
NOTES:
  • The Partition Count priority is applied in the following sequence (top to bottom):
    1. Topic level
    2. Application level
    3. Property level
  • The event processor create topic gets the partition count for that topic.
    • If the topic exists, it checks for an existing partition count and deletes the topic if it has a different value, and then creates it with the provided partition count.
  • Kafka server with auto topic creation on connect will cause issues due to preemptive metric collector component.
    This can be fixed with Kafka-client version 2.3 onward upgrade and adding "allow.auto.create.topics=false" in KafkaConsumer properties for TopicMetricsThread:
    • PreviewSubscriptionThread
    • TopicInputSchemaRepository
Default Value
1
Property
CEP: Kafka
Attribute
cep.kafka.watcher.wait
The interval (in milliseconds) at which Streams will check the status of the ZooKeeper, Kafka Broker, and Schema Registry services.
Default Value
5000
Property
CEP: Kafka
Attribute
cep.kafka.zookeeper.servers
The URL to the ZooKeeper servers.
Default Value
localhost:2181
Property
CEP: Kafka
Attribute
cep.type
The CEP type. For now, the available value is KAFKA.
Default Value
KAFKA
Property
Server Cluster
Attribute
cluster.bully.bind
The URL of the server in bully mode. This should be the URL to the Panopticon server web application on the server itself, by which is reachable from the other servers.
Default Value
Property
Server Cluster
Attribute
cluster.bully.boot
Comma-separated list of server URLs in bully mode.
At least one of these servers should be running at all time for the bully mode to work correctly. The URLs should be the same as the cluster.bully.bind value on each
boot server.
Default Value
Property
Server Cluster
Attribute
cluster.bully.id
The unique server ID in bully mode.
Can be any string, but do not change it after the server has participated in a cluster -- the other servers will store it and expect it to identify the same server in the
future. The running server with the lowest ID lexicographically will be leader.
Default Value
Property
Server Cluster
Attribute
cluster.fixed.leader
The leader URL in fixed mode.
This should be the URL to the Panopticon server web application on the preset leader server, by which it is reachable from the follower servers. Leave blank on the leader server itself.
Default Value
Property
Server Cluster
Attribute
cluster.kubernetes.container_name
Optionally name of the container that runs the Panopticon server, if the pod also runs other containers. If left blank, the first container will be used.
Default Value
Property
Server Cluster
Attribute
cluster.kubernetes.id
Set to the name of the pod that runs the container.
Default Value
Property
Server Cluster
Attribute
cluster.kubernetes.label_selector
Standard Kubernetes label selector that should only match the pods that are running the server.
Default Value
Property
Server Cluster
Attribute
cluster.mode
NONE (default), FIXED, BULLY, or KUBERNETES
Controls how multiple servers connect to each other. This needs to be  the same on all connected servers.
Default Value
NONE
Property
Server Cluster
Attribute
cluster.shared.secret
Any alphanumeric string.
Secret used to encrypt a challenge in peer-to-peer communication handshake. Needs to be the same, and non-empty, on all connected servers.
Default Value
Property
Server Cluster
Attribute
cluster.shared.store.shared_directory.path
Shared store location in SHARED_DIRECTORY mode.
This path must be reachable by all connected servers, and must point to the same physical directory on all of them.
Default Value
Property
Server Cluster
Attribute
cluster.shared.store.type
PRIVATE_DIRECTORY (default) or SHARED_DIRECTORY
The shared store is used to store information that should be synchronized between servers but is not content, for example authentication tokens. If you have a tightly-coupled cluster, e.g., behind a load balancer, it is recommended that you configure this as a shared directory.
Default Value
Property
AMPS Connector Custom Authenticator
Attribute
connector.amps.authenticators
This property is required when a custom authenticator is needed for AMPS connection. A custom authenticator needs be implemented as java .JAR file. The property excepts a JSON object, where key is fully qualified name of the Authenticator Java class, and values are list of constructor parameter names, e.g., “{"com.panopticon.examples.amps.AMPSClientAuthenticator":["User","Shared Key"]}”
Default Value
Property
Host Lookup
Attribute
connector.kdb.host.lookup.script
Full path of the shell script file that is accessible on the server. When set, before making a new kdb+ connection, this script is executed to get the host info. This
property helps in overriding connection details entered inside the kdb+ connector UI centrally, and may help when different authentications are set at kdb+ like Kerberos/Custom etc. The output of this script is expected to be a JSON object like below.
{ "host": "localhost", "port": 5001, "username": "", "password": "" }
Default Value
Property
Host Lookup
Attribute
connector.kdb.host.lookup.script.arguments
Delimited set of arguments to be passed to the script when it is executed. ’{host},{port},{userid},{password}’
is the default value, and these parameters are mapped to respective settings in the connector UI i.e., the value entered against these settings in the connector UI are
passed as arguments to the script.
This property can be extended or updated if you want to pass other datatable parameters as arguments. System parameter like {_user_id} or {_workbook_folder}, if added to the data table, can also be used. If the value of some parameter is null or empty at the time of execution of the script, two single quotes are passed (‘’) against that parameter, this is to make sure that arguments count matches the arguments set at this property.
Default Value
Property
Host Lookup
Attribute
connector.kdb.host.lookup.script.arguments.delimiter
Used to split the arguments set at above property.
Default Value
Property
Host Lookup
Attribute
connector.kdb.host.lookup.script.timeout
The timeout (in milliseconds) to wait for the host lookup script to run and return the host info.
Default Value
5000
Property
Amazon Kinesis – Data Streams connector
Attribute
connector.kinesis.datastreams.accesskeyid
The Access Key ID from the AWS account.
Default Value
Property
Attribute
connector.kinesis.datastreams.secretaccesskey
The Secret Access Key ID from the AWS account.
Default Value
Property
Python connector
Attribute
connector.python.host
The default Python Pyro instance host address.
NOTES:
For connector.python.host, connector.python.password, connector.python.port, and connector.python.serializertype properties:
  • If set in the Streams.properties file, these fields will be hidden in the Python connector and will be applied to the Python transform as well.
  • These default Streams Server connection properties will be applied at runtime.
  • These default Streams Server connection properties will override old Python connection settings.
Default Value
Property
Python connector
Attribute
The default HMAC Key.
Default Value
Property
Python connector
Attribute
The default Python Pyro host port.
Default Value
Property
Python connector
Attribute
The default Python serialization type. Possible values are serpent or pickle.
Default Value
Property
Rserve connector
Attribute
connector.rserve.host
The default Rserve host address.
NOTES:
For connector.rserve.host, connector.rserve.password, connector.rserve.port, and connector.rserve.userid properties:
  • If set in the Streams.properties file, these fields will be hidden in the Rserve connector and will be applied to the R transform as well.
  •  These default Streams Server connection properties will override old Rserve connection settings.
Default Value
Property
Rserve connector
Attribute
The default password that will be used to connect to the Rserve service.
Default Value
Property
Rserve connector
Attribute
The default Rserve host port.
Default Value
Property
Rserve connector
Attribute
The default user Id that will be used to connect to the Rserve service.
Default Value
Property
REST Documentation
Attribute
documentation.enabled
Enable or disable the OpenAPI Specification documentation for the REST interface.
Default Value
false
Property
REST
Attribute
error.default.message
The error message that will be displayed instead of the actual error message. This is used to mask or hide error messages that may contain internal or sensitive details.
Default Value
Property
File Upload
Attribute
file.upload.size.max.bytes
Limit for files size to be uploaded through the web browser (i.e., workbooks, streams applications, streams data sources).
Default Value
30000000
Property
Log level
Attribute
logger.level.file
Controls the level that is logged to file.
Default Value
INFO
Property
Server Metrics
Attribute
metrics.authorization.level
Specifies the required authorization level to get server metrics. Available values are ANONYMOUS, VIEWER, DESIGNER, ADMINISTRATOR.
NOTE: This property is case sensitive.
Default Value
ADMINISTRATOR
Property
Server Metrics
Attribute
metrics.collection.rate
Specifies the rate at which metrics are collected in milliseconds.
Default Value
1000
Property
Server Metrics
Attribute
metrics.file.flush.rate
Specifies how often metrics should be saved to disk in milliseconds. Only used if metrics.publisher.type is set to FILE.
Default Value
10000
Property
Server Metrics
Attribute
metrics.memory.queue.size
Specifies how many metric entries are stored in memory. When the number of metrics goes above the specifies value, the oldest value is removed to make room for the newest one (FIFO). Only used if metrics.publisher.type is set to MEMORY.
Default Value
100
Property
Server Metrics
Attribute
Specifies the current metric publisher that is used. Available values are NONE, MEMORY, FILE, EMAIL, INFLUX_DB, JDBC, KAFKA, KDB, MQTT, REST, TEXT.
Default Value
MEMORY
Property
Server Metrics
Attribute
metrics.publisher.configuration
Specifies the id for which metric publisher configuration to use.
Default Value
Property
Repository
Attribute
repository.import.archived.applications
Allows to import all application backups from the <appdata>/CEP/Archive/.
Refer to step 4 in the Migration to Streams Server 2023.2 from an Older Version section for more information.
Default Value
true
Property
Repository
Attribute
repository.startup.filesystemcheck
If set to true, server runs on startup to verify the repository integrity and reports any of the following issues:
  • a deleted /HEAD file,
  • a modified /HEAD,
  • a modified /refs/heads/master file,
  • any file deleted inside /objects/ (e.g., /objects/94/443eec118fb8bb2021071896ff7d386a9c9518),
  • any file modified inside /objects/.
NOTE: There may be dangling files in the /objects/ directory or those that are not in use. These files are typically results of failed saves and/or sync conflicts.
The check may or may not detect deleted or modified dangling files, but that is not critical.
Default Value
false
Property
REST
Attribute
rest.response.error.stacktrace.included
Include the error stackrace in REST responses.
Default Value
false
Property
Server Downgrade
Attribute
server.force_downgrade
The server normally refuses to start if it detects that the AppData directory has been used by a server with a newer version. This is because downgrading content and other AppData files is not supported and can cause irreversable issues. You can set
this property to true to force the server to start anyway, but it is strongly recommended that you do not.
Default Value
false
Property
Server
Attribute
server.id
Specifies an id for the current server. The value of this property will be part of each metric entry so that it can be tied to a specific server if a server cluster is used. If no value is specified, the MAC address of the localhost network will be attempted to be used to identify the server. If this is not possible, a UUID will be generated.
Default Value
Property
Licensing
Attribute
license.hwu.hosted
Boolean stating if you wish to use Managed or Local Altair Units licensing. Set to true if you wish to use managed licensing.
Default Value
false
Property
Licensing
Attribute
license.hwu.hosted.authorization.username
Username to the Altair One account.
Default Value
Property
Licensing
Attribute
license.hwu.hosted.authorization.password
Password to the Altair One account.
Default Value
Property
Licensing
Attribute
license.hwu.hosted.authorization.token
An authorization token generated through the Altair One admin portal. Used to authorize a machine to the managed Altair Units system.
Default Value
Property
Licensing
Attribute
license.hwu.uri
The path where the License Server is running e.g., 6200@191.255.255.0 where the syntax is PORTNUMBER@HOST. If multiple servers are specified, use the ‘;’ semicolon separator sign for Windows and the ‘:’ colon separator sign for Linux.
NOTE:
If value is not set in the Streams.properties, the environment variable ALTAIR_LICENSE_PATH serves as the backup path and will be used.
For Windows:
license.hwu.uri=6200@192.168.5.51;6200@192.168.5.52
For Linux:
license.hwu.uri=6200@192.168.5.51:6200@192.168.5.52
Default Value
Property
Licensing
Attribute
license.hwu.use_client_timezone
Determines how the ALJDK should process the timezone details. If set to true, the ALJDK will process the timezone details sent by Panopticon client to the Panopticon server. If set to false, the Panopticon server timezone is used.
Default Value
true
Property
Licensing
Attribute
license.mode
The license mode. Possible values are: FILE or HWU. To use the Altair Units license, set this property to HWU.
Default Value
FILE
Property
Timeout Session
Attribute
timeout.session.enabled
Boolean value stating if timeout functionality should be used or not.
Default Value
false
Property
Timeout Session
Attribute
timeout.session.exception.delimiter
The delimiter to use for the usernames stated in the timeout.session.exception.usernames property.
Default Value
, (comma)
Property
Timeout Session
Attribute
Usernames that should be excluded from the timeout functionality. Separated by the delimiter stated in the timeout.session.exception.delimiter property.
Default Value
Property
Timeout Session
Attribute
timeout.session.minutes
Minutes of inactivity before a user session is terminated by logging out the user.
Default Value
480
(c) 2013-2024 Altair Engineering Inc. All Rights Reserved.
