OAuth 2.0
This section discusses how to configure Panopticon Streams to use the OAuth 2.0 for authorization. Upon a logon request, Panopticon Streams will redirect the user to the Login page provided by the OAuth 2.0.
Note that OAuth 2.0 does not normally provide support on how to authenticate the user, Panopticon Streams will only know if the user is authorized or not. To authenticate the user, Panopticon Streams can be configured to use a REST service to extract the user identity with an access token retrieved from the OAuth 2.0 provider. In addition to the standard OAuth 2.0 configurations, the server includes properties (i.e., authentication.oauth2.*) that are specifically used to extract the user details.
authentication.type=OAUTH2
Property Description
authentication.oauth2.client.id
The ID of the OAuth 2.0 client.
authentication.oauth2.client.secret
The secret used by the OAuth 2.0 client.
authentication.oauth2.identity.attribute.username
The attribute that will be extracted from the identity response and used as the username.
authentication.oauth2.identity.url
The URL to the REST service that provides details about the  authenticated user.
authentication.oauth2.login.callback.url
The callback URL. The URL should be the same as one of the specified callback URLs used by the client. The URL should refer to Panopticon  Streams
authentication.oauth2.login.response.type
The response type. The only response type that is currently supported is CODE. The value can also be left blank.
authentication.oauth2.login.scope
The requested scope. The field can be left blank.
authentication.oauth2.login.url
The URL to the OAuth 2.0 login resource.
authentication.oauth2.logout.url
The URL to the OAuth 2.0 logout resource. This field can be left blank.
authentication.oauth2.token.method
The method on how the token should be retrieved. Supported values are QUERY, BODY, and HEADER.
authentication.oauth2.token.url
The URL to the OAuth 2.0 token resource.
authentication.oauth2.client.id=ClientId
authentication.oauth2.client.secret=ClientSecret
authentication.oauth2.identity.attribute.username=name
authentication.oauth2.identity.url=https://oauth2/me
authentication.oauth2.login.callback.url=http://localhost:8080/panopticon/server/rest/auth/login
authentication.oauth2.login.response.type=CODE
authentication.oauth2.login.scope=
authentication.oauth2.login.state=
authentication.oauth2.login.url=https://oauth2/authorize
authentication.oauth2.logout.url=
authentication.oauth2.token.method=QUERY
authentication.oauth2.token.url=https://oauth2/access_token
(c) 2013-2024 Altair Engineering Inc. All Rights Reserved.
