Creating MQTT Publisher Input Data Source
The MQTT Publisher connector allows writing message to a MQTT topic.
- Enter the following properties:
Property Description Broker URL
The location of the message broker. Default is tcp://localhost:1883.
Topic
The topic or the queue physical name.
Example:
level1/level2/level3/level4 etc.
NOTES:
You can also opt to use a wild card in the topic name specification.
- The plus sign symbol (+) can be used as a wild card for any value at one specific level.
Example: level1/level2/+/level4
- The hash sign symbol (#) can be used as a wild card for any values across more than one level.
Example: level1/#/level4
User Id
The user Id that will be used to connect to MQTT Publisher.
Password
The password that will be used to connect to MQTT Publisher.
- To allow encrypted connections, select the CA Certificate, Client Certificate, and Client Key by clicking Browse
to browse to the file sources. - For Payload, enter the data that you want to send as message. The format can be anything supported by MQTT broker, typically JSON.
NOTE: Prepend 'default:' for the elements falling under default namespace.
