Creating InfluxDB 2.x Input Data Source
The InfluxDB 2.x connector allows for the retrieval of a JSON data set from InfluxDB 2.x and above.
  1. On the Data Source tab, select Input > InfluxDB 2.x in the Connector drop-down list.
  2. Enter the following information:
    Property Description
    URL
    InfluxDB 2.x host address. Default is http://localhost:8086.
    Token
    The generated token that will be used for authentication.
    Organization
    The organization where the token belongs.
    Database
    The name of the database that will communicate over the HTTP(S).
  3. For the Query Type, select one from:
    • Flux Query
      Enter a Flux query for advanced time series data.
    • InFlux Query
      Enter an Influx (SQL-style) query to fetch data.
  4. Click  . The new data source is added to the Data Sources list.
