Creating DolphinDB Input Data Source
The DolphinDB connector allows you to connect and query tables using DolphinDB java API.
  1. In the New Data Source page, select Input > DolphinDB in the Connector drop-down list.
  2. Enter the following information:
    Property Description
    Host
    DolphinDB host address.
    Port
    DolphinDB host port. Default is 8848.
    User Id
    The username used to connect to the DolphinDB service.
    Password
    The password used to connect to the DolphinDB service.
    Select the Show Characters checkbox to display the entered password characters.
  3. Enter the Query, which can contain parameters in a similar manner to the database connector.
  4. Click  . The new data source is added in the Data Sources list.
