Converting Timestamp to/from Integer
Allows you to convert Timestamp values to/from Integer which include the following examples:
  • From posix to timestamp
  • From posixmillis to timestamp
  • From timestamp to posix
  • From timestamp to posixmillis
The conversion uses the expression: to([typename],[expression],[format]
Examples:
  • to(int, timefieldname, 'POSIX')
  • to(time, intfieldname, 'POSIX')
