Connecting to the CEP Engine
Starting with version 2021.0, the “local” or “internal” Kafka connectivity is deprecated. To connect to the CEP engine, use the external setup.
NOTE: Before connecting to the CEP engine, ensure the following are running:
- Confluent Kafka Enterprises services if you are using a Dockerized Kafka.
- ZooKeeper, Kafka, and Schema Registry batch files if you are using a local cluster.
Click
to connect to the external Kafka.
