Adding Groups and Users with Denied Access
- Right-click on a folder (except the root folder) and select Permissions in the context menu.
The Permissions dialog displays.
- Under the Denied section, click the Add
icon.
A new User/Group Denied section is displayed.
- Select User or Group that will be given denied permission in the drop-down list.
- Enter the user or group Name.
- Select the denied permission level that will be granted to the user or group:
- MODIFY
Prevent user or group to modify and create subfolders.
- WRITE + MODIFY
Prevent user or group to modify and write to the folder.
- READ + WRITE + MODIFY
Prevent user or group to modify and create subfolders, modify and write to the folder, as well as read the folder.
- MODIFY
- Click
. The user or group is added under the Denied list.
Repeat until all of the users with denied access are added.
- You can either:
- Select the Apply Permissions to Subfolders checkbox
This means the permissions that will be used on all of the subfolders will be fetched
from the root folder.NOTE: The Apply Permissions to Subfolders checkbox is only enabled when there is an existing subfolder.
- Leave the Apply Permissions to Subfolders box unchecked and modify the permission properties of the subfolders
- Click
to save the changes.
