Adding Groups and Users with Allowed Authorization
A user with an Administrator or Designer role can grant permission for users or groups access to application or data source folder or subfolder.
- Right-click on a folder (except the root folder) and select Permissions in the context menu.
The Permissions dialog displays.
- Under the Allowed section, click the Add
icon.
A new User/Group Allowed section is displayed.
- Select User or Group to be given permission in the drop-down list.
- Enter the user or group Name.
- Select the permission level that will be granted to the user or group:
- READ
Permission to read the folder.
- READ + WRITE
Permission to write to the folder and read.
- MODIFY + WRITE + READ
Permission to read, modify, and write to the folder as well as create subfolders.
- READ
- Click
. The user or group is added under the Allowed list.
- You can either:
- Select the Apply Permissions to Subfolders checkbox
This means the permissions that will be used on all of the subfolders will be fetched from the root folder.
NOTE: The Apply Permissions to Subfolders checkbox is only enabled when there is an existing subfolder.
- Leave the Apply Permissions to Subfolders box unchecked and modify the permission properties of the subfolders
- Click
to save the changes.
NOTE: You can copy the user names in the Permissions dialog by highlighting the text then right-clicking, and selecting Copy in the context menu.
