Updating Folder or Subfolder Properties
- To update folder properties, click a folder or a subfolder.
 - Right-click on the folder or subfolder and select Permissions.
The corresponding Permissions dialog displays.
 - Make the necessary changes such as new folder name, add or delete users and groups.
 - You can either:
- Select the Apply Permissions to Subfolders checkbox
This means the permissions that will be used on all of the subfolders will be fetched from the root folder.
 - Leave the Apply Permissions to Subfolders box unchecked and modify the permission properties of the subfolders
NOTE: The Apply Permissions to Subfolders check box is not enabled when defining the permissions for a subfolder.
 - Click
  to save the changes.
