Supported User Roles
Panopticon Real Time supports different user roles. To have full access to all the services, the user is required to have an ADMINISTRATOR and DESIGNER roles.
For example, logging on using the ADMINISTRATOR role (i.e., admin/admin), will display:
All of the available user specific folders in the authentication method used are displayed.
However, logging on with a DESIGNER role (i.e., designer/designer) will only display:
The allowed features available for the DESIGNER role is extensively discussed in the Web Authoring Guide.
