Setting Server Properties Through the Environment Variables
Server properties set in the Panopticon.properties file in the AppData folder (i.e., /etc/panopticon/appdata) are overridden by environment variables.
For example, you can supply a JSON object through the environment variable SPRING_APPLICATION_JSON that will be parsed during server start up:
"server.id": "Test_Server",
"subscription": {
"data.loading.pool.max.size": "5",
"broadcasting.pool.max.size": "6"
NOTE: Ensure that you minify the JSON object before setting the environment variable.
This will override and set the following property values:
server.id=Test_Server
subscription.data.loading.pool.max.size=5
subscription.broadcasting.pool.max.size=6
As seen from the example above, you can use inline JSON annotations for properties that share the same prefix, which in this case is subscription.
To override a single property, create an environment variable with the same name, but replace each '.' with an '_' and use upper case.
Example: Override the property server.id
Value: <some value>
You can also override individual properties with environment variables. Just set a variable with the same name as the property but with all letters in upper case and periods replaced with underscores. For example, REPOSITORY_STARTUP_IMPORT_PATHS will override the repository.startup.import.paths in Panopticon.properties.
