Implications of Moving a Workbook to Another Server
If a workbook using a custom map tile provider is exported from one Panopticon server and imported into another Panopticon server which does not have a custom map tile provider by that providerId name, then the Map Plot will display as blank--only marks/dots will show, but no map images. This can be corrected by changing the configuration of the Map Plot to use the Default map tile provider, or any other custom map tile provider added to that server.
