General Settings
You can allow anonymous users to use Panopticon. In this mode, a user can browse workbooks and view them without first logging in. The UI will display a
button that users can click to authenticate and get their normal permissions.
Permission settings can be done in the following properties:
| Property | Description |
authentication.required |
Set to false to allow anonymous use. The default value is true. |
authentication.logout.success-url |
When a user logs out of Panopticon by clicking the Logout button at the bottom of the right-hand profile pane, they are normally redirected back to the Welcome page. If you have authentication required, this will trigger authentication again, and if you use single sign-on your user may be automatically logged in again. Add and set to send users somewhere else. NOTE: This can also be useful if you are hosting Panopticon inside a larger application. |
