Environment Promotion Options
You may need to set up multiple environments for Panopticon. For example, you may wish to set up your system to support one of the following migration paths:
  • Staging à Production
  • Development à User Acceptance Testing àProduction
The primary complication when promoting workbooks between environments is access to data repositories since you may wish to use separate data repositories for each environment. If you require different data repositories in each environment, use
JNDI or global parameters. These abstract the location of the data repository from the workbook.
