Defining the Color Palettes of a Theme
When you define the settings of the color palettes, you can manage, import, or export Text, Sequential, and Diverging color palettes.
  1. To select the Single, Sign, Text, Sequential, and Diverging color palettes to use within the workbooks, click the Color Palettes tab.
    NOTE: For more information on how to create, modify, duplicate, or delete Single, Sign, Text, Sequential, or Diverging Palettes, refer to the Color Palettes sections.
  2. Select the checkboxes of the provided color palettes that will be included for each category.
  3. Click the radio button of the preferred Default color palette for each category.
  4. To upload color palettes, click  . The Upload Color Palette dialog displays.
  5. To export color palettes, you can either:
    • Click   for all color palettes. The ColorPalettes.excp file is exported.
    • Click the Export Palette  icon of a color palette. The <ColorPaletteName>.excp file is exported.
    You can move the exported file to the desired location.
  6. To replace the color palettes, select the Replace Color Palettes checkbox.
  7. Click  .
    A notification displays once the color palettes file is uploaded.
     Click  to close the dialog. The uploaded color palette is added in the list.
  8. Proceed to the General Colors tab to specify the general colors of the theme.
