Creating Task to Extract Data
Tasks can be created to reload workbook or global extracts.
- On the New Task pane, enter the Name of the task. Ensure the name is unique.
- Tap the Activated slider to turn it on.
- Select the Trigger. You can either select:
- Period then enter the Interval (in seconds), or
- CRON then enter a CRON Expression on the format:
- Select the task Type: Extract Data.
- Enter the Description of the task.
- Select the data extract to be scheduled in the Extract Name drop-down list box. The list is taken from the data extracts list on the Extracts tab.
- Click
- Once saved, you can opt to click
to manually run the task. - Click
to go back to the Tasks pane. A new task is added to the list.
