Configuring setenv.sh or setenv.bat
Configuration is done by adding a setting in the setenv.sh (for Linux) or setenv.bat (for Windows) in the <CATALINA_HOME>/bin/ folder. If the setenv.sh or setenv.bat file does not exist, you must create it.
Windows
Point out the Java installation to use.
Add the following lines:
set JAVA_HOME=JDK_home\[JDK folder]
      set JRE_HOME= JDK_home\[JDK folder]
Set the UTF-8 character encoding.
Add the following line:
set JAVA_OPTS=%JAVA_OPTS% -Dfile.encoding=UTF-8
Enable Arrow Serialization.
With Java 17, this setting is necessary for loading Apache Arrow files and for using Arrow serialization with Python. Add the following line:
set JAVA_OPTS=%JAVA_OPTS% --add-opens java.base/java.nio=ALL-UNNAMED
set JAVA_HOME=C:\Program Files\RedHat\java-17-openjdk-17.0.10.0.7-2
      set JRE_HOME=C:\Program Files\RedHat\java-17-openjdk-17.0.10.0.7-2
Finally, save the file setenv.bat.
For further details, see the Apache Tomcat 10 documentation.
Linux
JAVA_HOME=/path/to/jvm/version
      JRE_HOME=/path/to/jvm/version
JAVA_OPTS="$JAVA_OPTS -Dfile.encoding=UTF-8"
JAVA_OPTS="$JAVA_OPTS --add-opens java.base/java.nio=ALL-UNNAMED"
JAVA_HOME=/usr/lib/jvm/java-1.17.0-openjdk-amd64
      JRE_HOME=/usr/lib/jvm/java-1.17.0-openjdk-amd64
Finally, save the file setenv.sh.
NOTE:
If you don’t have the correct Java Options setting for Arrow, you will see the following error message when trying to load an Arrow file:”
Handler dispatch failed: java.lang.ExceptionInInitializerError
The Tomcat console will log:
java.lang.RuntimeException: Failed to initialize MemoryUtil. Was Java started with --add-opens=java.base/java.nio=ALL-UNNAMED? (See https://arrow.apache.org/docs/java/install.html)
<etc..>
Caused by: java.lang.reflect.InaccessibleObjectException: Unable to make field long java.nio.Buffer.address accessible: module java.base does not "opens java.nio" to unnamed module @2322f814
