Configuring Server Logs
Panopticon Real Time is preconfigured with recommended logging settings for performance. All of the logging will be directed to a file prefixed by Panopticon in the Tomcat logs folder. The Panopticon-specific logging configuration file is located inside the .warfile at WEB-INF/classes/logging.properties. This configuration takes precedence over the general Tomcat logging configuration. If the logging is to be configured in Tomcat, the file WEB-INF/classes/logging.properties must be removed from the .war file.
