Configuration of the Client Properties
Starting with version 2020.1, Panopticon Real Time generates JSON configuration files in the JavaScriptConfiguration directory of the AppData folder (i.e., /etc/panopticon/appdata).
NOTE: In the JSON files, a dot in the name (e.g., name1.name2) is used to denote a nested object structure:
"name1": {
"name2": ...
The default content of the admin.json file has the following objects/names:
"baseUrl" : ".",
"hideAuthenticationButton" : false,
In the admin.json file, you can control the configuration of the following objects/names:
Object/Name |
automaticReconnectOnServerDisconnect |
Description |
If set to true, the real time connection (WebSocket or long polling) to the Panopticon server will be automatically reconnected if it is disconnected. |
Default Value |
false |
Required |
No |
Object/Name |
baseUrl |
Description |
Location of Panopticon Real Time. |
Default Value |
Required |
Yes |
Object/Name |
dataLoading.transport |
Description |
Controls which transport should be used when viewing log from the server. Valid values are "websocket" and "long-polling". If configured to "websocket", but the WebSocket connection fails, then the web client will automatically fall back to "long-polling". |
Default Value |
"websocket" |
Required |
No |
Object/Name |
hideAuthenticationButton |
Description |
Boolean. Hides the login and logout buttons. |
Default Value |
false |
Required |
No |
Object/Name |
localization.defaultLocale |
Description |
Locale used if the browser locale is not supported, or if the useBrowserLocale is set to false. |
Default Value |
"en-US" |
Required |
No |
Object/Name |
localization.fallbackLocale |
Description |
Locale used if a resource string is missing from the locale in use. Should be specified if localization.defaultLocale is specified. |
Default Value |
value of localization.defaultLocale |
Required |
No |
Object/Name |
localization.useBrowserLocale |
Description |
Boolean. If set to true, the browser navigator.language, navigator.userLanguage on IE11, controls the localization of the UI. Not all languages are supported. |
Default Value |
true |
Required |
No |
Object/Name |
localizationOverride |
Description |
Nested object with resource strings per language. Used to customize resource strings. |
Default Value |
Required |
No |
Object/Name |
logLevel |
Description |
Controls which types of logs Panopticon will write to the browser dev console. Valid values are: "trace", "debug", "info", "warn", "error" and "silent". |
Default Value |
"info" |
Required |
No |
Object/Name |
workbookUrl |
Description |
Location of the workbook application. NOTE: The workbookUrl property should reflect the actual location of the workbook |
Default Value |
"workbook" |
Required |
Yes |
Object/Name |
dataLoading.connectTimeout |
Description |
Controls the timeout used, in milliseconds, when opening the data loading connection to the server. |
Default Value |
10000 |
Required |
No |
Object/Name |
showFileUploadUI |
Description |
Controls the visibility of UI that is used to upload a file to the server. |
Default Value |
true |
Required |
No |
Object/Name |
showLinkToFileUI |
Description |
Controls the visibility of UI that is used to specify a data file on the server local file system as a data source. Per default, this flag is automatically inserted into the client configuration at runtime. |
Default Value |
true |
Required |
No |
Object/Name |
visibleViewerTabs.datatables |
Description |
Controls only visibility of Data Library tab for viewer role. |
Default Value |
true |
Required |
No |
Object/Name |
visibleViewerTabs.webhooks |
Description |
Controls only visibility of Webhooks tab for viewer role. |
Default Value |
true |
Required |
No |
Object/Name |
visibleViewerTabs.alerts |
Description |
Controls only visibility of Alerts tab for viewer role. |
Default Value |
false |
Required |
No |
Object/Name |
visibleViewerTabs.parameters |
Description |
Controls only visibility of Parameters tab for viewer role. |
Default Value |
false |
Required |
No |
Object/Name |
visibleViewerTabs.themes |
Description |
Controls only visibility of Themes tab for viewer role. |
Default Value |
false |
Required |
No |
Object/Name |
visibleViewerTabs.system |
Description |
Controls only visibility of System tab for viewer role. |
Default Value |
false |
Required |
No |
Object/Name |
visibleDesignerTabs.datatables |
Description |
Controls only visibility of Data Library tab for designer role. |
Default Value |
true |
Required |
No |
Object/Name |
visibleDesignerTabs.webhooks |
Description |
Controls only visibility of Webhooks tab for designer role. |
Default Value |
true |
Required |
No |
Object/Name |
visibleDesignerTabs.alerts |
Description |
Controls only visibility of Alerts tab for designer role. |
Default Value |
true |
Required |
No |
Object/Name |
visibleDesignerTabs.parameters |
Description |
Controls only visibility of Parameters tab for designer role. |
Default Value |
true |
Required |
No |
Object/Name |
visibleDesignerTabs.themes |
Description |
Controls only visibility of Themes tab for designer role. |
Default Value |
true |
Required |
No |
Object/Name |
visibleDesignerTabs.system |
Description |
Controls only visibility of System tab for designer role. |
Default Value |
false |
Required |
No |
Object/Name |
maxrowcount |
Description |
Controls the maximum number of rows a table can return. |
Default Value |
100000 |
Required |
No |
Object/Name |
preventDataLoadOnMaxRowCountExceeded |
Description |
Controls whether an exception is raised when number of rows from the data table exceeds maxRowCount or should the rows be truncated. |
Default Value |
true |
Required |
No |
Object/Name |
connectors.showLegacyButton |
Description |
Controls the visibility of the Show Legacy Connectors switch button in the select connector panel. Used to show/hide legacy connectors. |
Default Value |
true |
Required |
No |
Object/Name |
connectors.legacyVisible |
Description |
Default value of Show Legacy Connectors switch button in select connector panel. |
Default Value |
false |
Required |
No |
The default content of the workbook.json file has the following objects/names:
"baseUrl" : "..",
"forceClientSelectionHandling" : true,
"startUrl" : "../",
"dataLoading" : {
"transport" : "websocket"
"webGlEnabled" : true,
"pdfMultiplePagesEnabled" : true
In the workbook.json file, you can control the configuration of the following objects/names:
Object/Name |
baseUrl |
Description |
Default Value |
Required |
Yes |
Object/Name |
Description |
Default Value |
true |
Required |
No |
Object/Name |
Description |
Locale used if the browser locale is not supported, or if useBrowserLocale is set to false. |
Default Value |
"en-US" |
Required |
No |
Object/Name |
Description |
Default Value |
Required |
No |
Object/Name |
Description |
Default Value |
Required |
No |
Object/Name |
logLevel |
Description |
Default Value |
"info" |
Required |
No |
Object/Name |
disableExternalHelpText |
Description |
Disables the browser dev console splash screen. |
Default Value |
false |
Required |
No |
Object/Name |
theme |
Description |
Name of the default theme for all workbooks. Per default, the first theme available is picked as the default theme. |
Default Value |
Required |
No |
Object/Name |
allowOrigin |
Description |
A comma separated list of allow origins, used by the Panopticon POST message API. |
Default Value |
Required |
No |
Object/Name |
Description |
Default Value |
false |
Required |
No |
Object/Name |
alwaysHideNonInteractiveParametersInDialog |
Description |
Hides parameters that are not interactive when displaying the interactive parameter dialog. |
Default Value |
false |
Required |
No |
Object/Name |
enableDevicePixelRatioCanvasScaling |
Description |
Enable or disable handling of device pixel ratio for 2D visualizations. |
Default Value |
true |
Required |
No |
Object/Name |
staleStateTimeout |
Description |
Time (in milliseconds) that controls how fast the "stale data" overlay should be |
Default Value |
150 |
Required |
No |
Object/Name |
preloadDetailsPopup |
Description |
Data to be shown in the Details pop-up is preloaded as part of the visualization |
Default Value |
true |
Required |
No |
Object/Name |
forceClientSelectionHandling |
Description |
If set to true, then selection handling in the visualizations will be performed by |
Default Value |
false |
Required |
No |
Object/Name |
pdfMultiplePagesEnabled |
Description |
Controls the visibility of the "Create multiple pages..." checkbox in the ad hoc |
Default Value |
true |
Required |
No |
Object/Name |
startUrl |
Description |
URL used by the Home and Back buttons, and by the dialog for unexpected errors. |
Default Value |
Required |
No |
Object/Name |
useBrowserHistoryToNavigateBack |
Description |
If set to true, the Back button will execute window.history.back() when pressed. This setting takes precedence over having a configured startUrl. |
Default Value |
false |
Required |
No |
Object/Name |
hideThemeSelection |
Description |
Controls the visibility of the theme drop down. |
Default Value |
false |
Required |
No |
Object/Name |
Description |
Controls the which transport should be used when loading data from the server and receiving notifications. Valid values are "websocket" and "long-polling". If configured to "websocket", but the WebSocket connection fails, then the web client will automatically fall back on "long-polling". |
Default Value |
"websocket" |
Required |
No |
Object/Name |
Description |
Default Value |
10000 |
Required |
No |
Object/Name |
preventVisualizationMouseWheelDefaultEvents |
Description |
Prevents the browser default action when using the mouse wheel over a visualization. Useful in an embed scenario if the hosting web page is scrolled when the user tries to zoom in a visualization using the mouse wheel. |
Default Value |
false |
Required |
No |
Object/Name |
webGlEnabled |
Description |
Enables the use of WebGL in visualizations that supports it. |
Default Value |
true |
Required |
No |
Object/Name |
maxClipboardLength |
Description |
Maximum length of text that will be attempted to be put into the system clipboard (copy). If too much text is attempted, then the browser might become unresponsive. |
Default Value |
500000 |
Required |
No |
Object/Name |
selectionInDetailsPopup |
Description |
Enables/disables selection data in the visualization details popup. Primary use case for this setting is to disable it on a server level. |
Default Value |
true |
Required |
No |
Object/Name |
showAlertsButton |
Description |
Controls the visibility of the Alerts workbook button. |
Default Value |
true |
Required |
No |
Object/Name |
showBackButton |
Description |
Controls the visibility of the Back workbook button. |
Default Value |
true |
Required |
No |
Object/Name |
showBookmarksButton |
Description |
Controls the visibility of the Bookmarks workbook button. |
Default Value |
true |
Required |
No |
Object/Name |
showCopyDashboardImageButton |
Description |
Controls the visibility of the Copy Image workbook button. |
Default Value |
true |
Required |
No |
Object/Name |
showHomeButton |
Description |
Controls the visibility of the Home workbook button. |
Default Value |
true |
Required |
No |
Object/Name |
showPdfExportButton |
Description |
Controls the visibility of the Create PDF Report workbook button. |
Default Value |
true |
Required |
No |
Object/Name |
showRefreshDataButton |
Description |
Controls the visibility of the Refresh workbook button. |
Default Value |
true |
Required |
No |
Object/Name |
showPauseRealtimeButton |
Description |
Controls the visibility of the Pause Real-Time workbook button. |
Default Value |
true |
Required |
No |
Object/Name |
showExcelExportButton |
Description |
Controls the visibility of the Create Excel Report workbook button. |
Default Value |
true |
Required |
No |
Object/Name |
pluginDenyList |
Description |
Array of plugin IDs, used to block the specified dashboard parts and visualizations. |
Default Value |
empty array |
Required |
No |
Object/Name |
pluginAllowList |
Description |
Array of plugin IDs, used to allow only the specified dashboard parts and visualizations. The default value, an empty array, allows all plugins. |
Default Value |
empty array |
Required |
No |
Object/Name |
showFileUploadUI |
Description |
Default Value |
true |
Required |
No |
Object/Name |
showLinkToFileUI |
Description |
Default Value |
true |
Required |
No |
Object/Name |
partCreator.showLegacyButton |
Description |
Controls the visibility of the Show Legacy switch button in the Select part panel. Used to show/hide legacy visualization parts. |
Default Value |
true |
Required |
No |
Object/Name |
partCreator.legacyVisible |
Description |
Default value of Show Legacy switch button in select part panel. |
Default Value |
false |
Required |
No |
Object/Name |
maxrowcount |
Description |
Default Value |
100000 |
Required |
No |
Object/Name |
Description |
Default Value |
true |
Required |
No |
Object/Name |
Description |
Default Value |
true |
Required |
No |
Object/Name |
Description |
Default Value |
false |
Required |
No |
Object/Name |
autoBucketingEnabled |
Description |
Controls if automatic time bucketing columns should be created. |
Default Value |
true |
Required |
No |
NOTE:
- With the new application configuration files, the workbook/config.js inside the extracted war file is no longer valid.
- If there are no config files available on the server, default ones will be created and saved. After that, you can alter them in any way you would like and keep the configuration even if the server is restarted.
