Creating Task to Clear and Import Data Table to Data Store
Allows you to clear the earlier imported data and import again to the data store.
- On the New Task pane, enter the Name of the task. Ensure the name is unique.
- Tap the Activated slider to turn it on.
- Select the Trigger. You can either select:
- Period then enter the Interval (in seconds), or
- CRON then enter a CRON Expression on the format:
sec mins hours dayofmonth month dayofweek (e.g., 09 02 18 ? * MON-FRI)
- Select the task Type: Data Store – Clear and Import.
- Enter the Description of the task.
- Select the Data Table Name that will be cleared in the data store and imported again.
- Click
- Once saved, you can opt to click
to manually run the task. - Click
to go back to the Tasks pane. A new task is added to the list.
