Working with Data Table Editor
Most of the sections in this editor are available in Workbook Internal Data Table Editor. However, you can only create a single data table in this editor. To join data tables, you can use the Joined Data Table Editor.
Data Table Editor Sections and Definitions
| Section | Description |
| 1 |
Back Exit the Data Table Editor and go to the Data Library page. |
| 2 |
Data Table Name Name of the data table. You can edit by entering a new one and clicking |
| 3 |
Data Table Settings Displays the data source that you will connect to. Click NOTE: Auto Refresh is disabled for data table in data store and connectors that only work on uploaded data or Upload File load type. These include the following connectors:
| 4 |
Data Table Parameters Add or manage data table parameters. |
| 5 |
Search Columns Allows searching of columns on the Data Preview. |
| 6 |
Collapse Data Profile Pane Collapse the Data Profile pane. Click |
| 7 |
Data Profile Pane Displays the following information:
| 8 |
Data Preview Executes the queries to return and display preview of the data table you are creating. NOTE: The maximum number of rows displayed in the Data Preview is 1000. |
| 9 |
Calculated Columns Allows you to view and manage the calculated columns. |
| 10 |
New Column Options Allows you to add any of the following columns:
| 11 |
When the Column Order is set to Sorted, the columns are grouped by type (Text, Date/Time, |
| 12 |
Column Profiling Perform column profiling either for the Top 1000 Rows or All Rows. |
| 13 |
Connector Settings Displays the connector settings of the data source and allows for limiting the amount of data to be returned. |
| 14 |
Data Policy Allows you to set the data policy for data tables in the Data Library. |
| 15 |
Import to Data Store Allows you to import the data table to a data store. |
| 16 |
Clear and Import to Data Store Allows you to clear the earlier imported data and import again to the data store. |
| 17 |
Save Data Table Saves the data table definition. |
| 18 |
Row Limits Settings Allows setting of the row limit of data sources. |
| 19 |
Refresh Preview Allows you to refresh the data preview. |
| 20 |
Collapse Data Preview Collapse the Data Preview pane. Click |
Clicking Transform Settings
displays the Transform Settings pane.
Transform Settings |
Allows you to perform the following:
Clicking Columns
displays the Columns Settings pane.
Column Settings |
Clicking Advanced
displays the Advanced Settings pane.
| 1 |
Error Message Allows you to enter custom Error Message that will be displayed when an error occurs while fetching data. Can be parameterized. |
| 2 |
Includes Aggregate Data Allows you to retrieve external aggregates. |
| 3 |
Export Raw Data Specify the set of columns to be included when exporting raw data |
Clicking Debug
displays the Debug pane.
| 1 |
Data Table ID Id of the data table. Can be used for parsing of server logs. |
| 2 |
Data Log Details Details of the data log which includes the data source name, response time, and duration (ms). |
| 3 |
Parameters Parameters on the data table. |
| 4 |
Logs Logs of the last query. |
to select another data source. Other data table definitions are displayed including the description and the auto refresh period (in seconds).
to expand the Data Profile pane.
