Time Period Calculations
Time Period calculations are like Time Window calculations but relative to the current time slice.
| Function | Description |
CONTINUE_NPREV |
Checks if there was a value in a previous time slice, N time slices back, and a One use case can be to “mark” that a series has a value (not NULL) in the current CONTINUE_NPREV is related to LEAVE_NPREV and JOIN_NPREV. |
COUNT_NPREV |
Returns the number of non-null time slice values across the defined range. Otherwise, it returns 0. |
DATEADD |
Adds an integer value to a specified DATEPART of an input date value, returning the modified value. Valid DATEPART values are YEARS, MONTHS, DAYS, HOURS, MINUTES, SECONDS, MILLISECONDS, MICROSECONDS, and NANOSECONDS. |
DATEDIFF |
The count of the specified DATEPART boundaries crossed between the specified StartDate and EndDate. Valid DATEPART values are YEARS, MONTHS, DAYS, HOURS, MINUTES, SECONDS, MILLISECONDS, MICROSECONDS, and NANOSECONDS. |
DATEDIFF2 |
The total amount of elapsed time between the StartDate and EndDate expressed in a Valid DATEPART values are YEARS, MONTHS, DAYS, HOURS, MINUTES, SECONDS, MILLISECONDS, MICROSECONDS, and NANOSECONDS. |
DATEDIFF_TO_NOW |
The total amount of time elapsed from Date until Today(start of day) expressed in given unit. Valid DATEPART values are YEARS, MONTHS, DAYS, HOURS, MINUTES, SECONDS, MILLISECONDS, MICROSECONDS, and NANOSECONDS. |
DATEDIFF_TO_TODAY |
The total amount of time elapsed from Date until Today(start of day) expressed in given unit. |
DELTA_NPREV |
Alias for “Measure”-NPREV(“Measure”,number). Calculates the change from the value N time slices previous, to the current value. DELTA_NPREV is related to DELTA_PCNT_NPREV |
DELTA_PCNT_NPREV |
Alias for “Measure”/NPREV(“Measure”,number)-1. Works exactly like DELTA_NPREV, but instead of delivering the nominal value of Value(N=3)-Value(N=1), it calculates the difference divided by Value(N=3), For example, moving from 5 to 2 gives you DELTA=-3 and DELTA_PCNT = -0.60 (-3/5). DELTA_PCNT_NPREV is related to DELTA_PCNT. |
FALL_NPREV |
Detects if a series has had a decreasing value when comparing the current time slice to a previous time slice. If the current value was lower, then the function returns FALL_NPREV is related to GAIN_NPREV. |
GAIN_NPREV |
Detects if a series has had an increasing value when comparing the current time sliceto a previous time slice. If the current value was higher, then the function returns 1. Otherwise, it returns 0. GAIN_NPREV is related to FALL_NPREV |
JOIN_NPREV |
Checks if there was a null value in a previous time slice, N time slices back, while One use case can be to “mark” that a series had a NULL in a previous time slice. JOIN_NPREV is related to LEAVE_NPREV and CONTINUE_NPREV. |
LEAVE_NPREV |
Check if there was a value in a previous time slice, N time slices back, while there One use case can be to “mark” that a series has a NULL in the current time slice, LEAVE_NPREV is related to JOIN_NPREV and CONTINUE_NPREV. |
MAX_NPREV |
The maximum value of current time and the value n time slices before that. |
MIN_NPREV |
The minimum value of current time and the value n time slices before that. |
NPREV |
The value of a measure n time slices previous of the current time. |
PRODUCT_NPREV |
The product of the values n time slices previous of the current time. |
SMA_NPREV |
The Simple Moving Average for the n time slices up to and including the current time slice. Alias for SUM_NPREV(“Measure”,number)/number. |
STDEV_NPREV |
Calculates the standard deviation for a number of preceding time slices. |
STDEVP_NPREV |
Calculates the population standard deviation for a number of preceding time slices. |
SUM_NPREV |
The sum of the values n time slices up to and includes the current time slice. |
TO_POSIX |
Converts timestamp values to posix. |
TO_POSIXMILLIS |
Converts timestamp values to posixmillis. |
WITHIN_PERIOD |
If the input date is within the period compared to the current timestamp, then the Usage Example: withinperiod(period, date, measure) where period is either of ["WTD","MTD","QTD","YTD"] "WTD" = week to date "MTD" = month to date "QTD" = quarter to date "YTD" = year to date |
NOTE: When using Time Period calculations, fields referenced by the calculation should be enclosed in double quotes and NOT square brackets.
For example, using the Time Series column PRICE, the following calculations can be created,
Change in Price compared to previous time slice |
[PRICE] - NPREV(“PRICE”,1) |
Change in Price compared to 5 time slices previously |
[PRICE] - NPREV(“PRICE”,5) |
% Change in Price compared to Previous Time slice |
( [PRICE] - NPREV(“PRICE”,1)) / NPREV(“PRICE”,1) |
5 Period Moving Average |
SUM_NPREV(“PRICE”,5)/5 |
20 Period Moving Average |
SUM_NPREV(“PRICE”,20)/20 |
