Connector for Panopticon Data Extract
The Panopticon Data Extract connector allows retrieval of global extracts created from non-streaming data sources in Panopticon Real Time.
In cases where there is too much data to retrieve into memory, data extract supports summarization and parameterization, and it can become a more powerful option than several underlying data sources.
- Select Panopticon Data Extract from the Connectors panel. The Panopticon Data Extract Settings panel displays the earliest created data extract (e.g., ExcelExtract).
The list of columns displays, with the data type found from inspecting the first ‘n’ rows of the file.
NOTE: To populate the list of columns, the data extract of a connector must be complete after refreshing the data.
You can also filter the list of columns by entering a text in the Search box.
- You can choose to select another data extract to display its list of columns.
- If the data returned is to be aggregated, then check their Column box. For each selected column, the possible aggregation methods are listed including:
- Text Columns: Group By
- Date Columns: Group By
- Numeric Columns: Sum, Count, Min, Max, Mean
Select the Aggregate method in the drop-down list.
- If you wish to parameterize a specific column, match the parameter to the appropriate column. By default, they will be matched on name.
- If only a selected Date/Time range of the table / view is to be queried, select the Constrain checkbox, and complete the From and To text boxes, either with values or with parameters.
