File/URL Data Sources
Connector for Altair AI Hub
The Altair AI Hub allows you to request data from endpoints created in Altair AI Hub.
- Enter or select the following properties:
Property Description Endpoint
Clicking
for the first time, or if the offline token is expired, you can enter it in the Offline Token dialog that displays.
Consequently, the offline token is cached at the AppData repository for subsequent usage.URL
The Endpoint on Altair AI Hub or RTSA URL.
Authentication Type
Select one from the following:
None
Can be used with Endpoints that have Consumer Permissions = “Public / anonymous”.
Basic
Can be used with Endpoints that have Consumer Permissions = “Basic authentication”, and a User Id and Password are entered. User Ids can be added to each specific Endpoint in Altair AI Hub, in the Deployment settings of the Endpoint.
API Token
Can be used with Endpoints that have Consumer Permissions = “Long-living API token”, and an API token is entered. API tokens can be created in Altair AI Hub, in the Deployment settings of the Endpoint.
Input Data
By default, this setting has a JSON object entered, with a single name “data” and a value which is a JSON array containing an empty JSON object. The array can contain some number of JSON objects, each being a single name-value pair of column names and column values. The required structure is further exemplified in the Test section of each Endpoint in Altair AI Hub.
Timeout
The time in seconds that will be allowed before Panopticon aborts the request. Possible values are one of a fixed set of seconds from 10 to 300.
- Click
to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled. - You can also opt to load or save a copy of the column definition.
- Click
to add columns to the Altair AI Hub connection that represent sections of the message. Then enter or select:
Property Description Name
JsonPath
The JsonPath of the source schema.
Date Format
Enabled
Determines whether the message field should be processed.
NOTE: To parse and format times with higher than millisecond precision, the format string needs to end with a period followed by sequence of upper case S. There can be no additional characters following them.
For example: yyyy-MM-dd HH:mm:ss.SSSSSS
To delete a column, select
or for all the column entries, select the topmost
, then click .
