Adding an Image Box
You can add logos or other graphics to a dashboard using an Image Box.
These can be retrieved from disk or retrieved at display time from an external URL.
- After double-clicking or drawing a rectangle on the dashboard canvas, scroll to the General section of the Part Types pane and select Image Box
The Image Box pane is displayed, and the Image Box part is added on the dashboard canvas.
- Select the Stretch Mode: Fit, Fill, or Stretch.
- Select the Vertical Align: Bottom
, Middle
, or Top
- Select the Horizontal Align: Left
, Center
, or Right
- You can either:
- Enter the URL of the image file in the Fetch from URL text box and click
This enables the Cross Origin Mode drop-down list which allows for cross-origin attribute configuration on the image when doing a Copy Dashboard Image. Available states include:
- Click
to browse the image file in the Open dialog.
- The Display in PDF slide to include the image in the PDF output.
- To set the style of the Image Box, click Style
The page updates to display the Style pane.
See Defining the Style of General Parts for more information.
- Click Update Style
and select any of the following options:
- Set current as default – Save the changes and set it as the default.
- Create custom style – Save the changes and set it as a custom style.
The Style pane updates to display the Title control.
- Enter the custom style's Title.
- If there are additional changes made, click Update Current Style in the Update Style drop-down.
The new custom style is added to the Workbook > Theme > Custom Styles list.
If published, the custom style configuration of the Image Box will be added to the Global custom styles list and can be applied to other parts.
- Reset to default – Revert to the original default settings.
- Click the Save
icon on the toolbar to save the changes.
