Z Variable Configuration
The Z variable is available in the 3D Surface Plot and 3D Scatter Plot visualizations and is used to set the height.
The configuration pane for the Z variable is the same as for the Size variable.
NOTE:
For the 3D Surface Plot and 3D Scatter Plot visualizations, you can set the visible range for the Z variable which can either be calculated dynamically (the default, enabled Dynamic).
Or set between predefined limits by clicking Fixed. This displays the Min and Max ext boxes that are populated with the default values taken from the data set.
