Variable Constant State
Most of the variables (Size, X & Y, Z, Latitude & Longitude, Price, Change, Opacity) have a Constant state by default. When enabled, the constant state can be used as value for the variable.
- On the Visualization Settings pane, click Y variable.
Initially, the constant state is disabled.
- Click the Constant<Variable> value to expand its settings.
- Tap the slider to turn on Enabled. Empty currently displays as the associated value of the Y variable.
- Set the Value and Format as required.
You can opt to modify the following properties:
Property Description Palette
The color of the associated variable.
General Colors
General color settings that were defined in the Workbook Theme.
