Single Selection Drop Down List
In the dashboard, this mode shows a radio button drop down list of distinct items that are alphabetically sorted when expanded. By default, the Show Select All option is enabled.
You can also opt to tap the Show Search Bar slider to turn it on.
Enter a particular column into the filter text box.
Only a single item or all items may be selected. When collapsed, it shows the summary text or the single selected item. For the example below, the region selected is Asia Pacific.
