Single Selection
In the dashboard, this mode shows a radio button list of distinct items that are alphabetically sorted. Only a single item or all items may be selected. By default, the Select All option is enabled.
You can also opt to tap the Show Search Bar slider to turn it on.
Enter a particular column into the filter text box.
