Parameterization of Connection Settings for Data Sources
Connecting to data sources typically requires application login. To be able to connect, you may need to enter the following information, depending on the connector:
- Host Name
- Port
- Server Name
- User Id
- Password
- Database
- On the Parameters pane of the Data Table Settings, define the connection settings you will use for the connector. Such as the following:
- Host
- User
- Pwd
- Server
- DB
- Port
- Click on a data source. The Data Source Settings pane is displayed.
- Parameterize the entries in the pane. For example:
- Click
for static connectors or
for streaming connectors then .
