Multiple Selection Drop Down List
Multiple Select Drop Down List is the default selection mode when the text filter column has 16 to 30 values.
In the dashboard, this mode shows a list of distinct items that are alphabetically sorted when expanded. By default, the Select All option is enabled.
Multiple items may be selected. When collapsed, the number of selected items is displayed.
You can also opt to tap the Show Search Bar slider to turn it on.
Enter a particular column into the filter text box.
Click Set Only Selected to apply the filter to the visualizations in the dashboard.
Or you can also enter one or more characters into the filter text box. The suggested list of columns that matched the entries will be displayed.
NOTE: Hovering on an active Multiple Selection Drop Down List filter displays the current selected values.
